by JamesBlonde Contributor
internet keeps dropping on wired connections
I've got a issue that I hoped would be solved by a new Brightbox router, but looks like I've still got problems.
I regularly get internet drop outs for up to 5-10 minutes on any device that has a wired connection into the router - wireless doesn't seem to be affected.  This affects my desktop PC and server, TV, EE TV Box and Sonos.
I use Powerline adaptors on my server and desktop PC as I'm in an old house and wireless just doesn't penetrate the walls.  The powerline adaptors are connected to a switch, and the switch connected to the router.
I added the TP Link 8 port Gigabit switch to see if that solved - or isolated - the problem.  Before the switch, I'd lose access to all of the wired devices in the house.  Now I have the switch installed, I can still access my wired devices during an internet outage.  So I think that would tend to indicate a problem at the router.
The error message I've been getting on the PC during the outage is:
“This site cannot be reached – DNS address could not be found.  Diagnosing the problem”
and then when running Windows Diagnostics:
“windows could not automatically detect this network’s proxy settings”
Whilst the problem appears to be random, I do maybe get the impression it's worse when I'm also using another device - when I start up Sonos for example, or start doing stuff on the server.  Also seems to be worse when streaming or downloading.
14 REPLIES 14
Re: internet keeps dropping on wired connections
Hi @JamesBlonde.
Welcome to the community 🙂
Are you able to try another socket in your home?
How frequently are these drop-outs happening?
Jon
Hi Jon,
Drop outs are happening many times (10+) a day, seemingly randomly.
Do you mean phone socket or electricity socket?
If phone, there is only 1 socket in the house. That was initially part of the problem as there was a severe line fault. That has been fixed, and the line tested again last week before the router was sent. As I mentioned, wireless connections seem fine.
If you mean power socket for the powerline, yep can give that a go - I've got 2 devices plus the router / switch running off powerline so will have to try them over a number of days to try to isolate the fault
Thanks @JamesBlonde.
I was meaning phone socket, but thanks for explaining that.
This particular problem goes a little beyond my knowledge I'm afraid, you could speak with our Broadband Tech team, or another community user may be able to give you a helping hand.
Jon
When this happens what does ipconfig /all say in the Ethernet section on your PCs?
Also post your full router stats:
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
My bad - it's a Smart Hub.  Anyway, Router stats (I'm assuming you can take these any time...) are:
Product nameEE Smart Hub
Serial number
 v0.00.24.06190-EE (Tue Jun 19 17:25:19 2018)
Board version1
Data sent / received273.1 MB / 1.8 GB
DSL uptime0 days 13 Hours 47 Mins 28 Secs
Data rate20.00 Mbps/72.71 Mbps
Maximum Data rate29.9 Mbps/82.7 Mbps
Noise margin (up/down)12.5/5.0
Line attenuation (up/down)14.0/14.7
Signal attenuation (up/down)13.9/14.7
Broadband username
2.4 GHz wireless network name
2.4 GHz wireless channelSmart (Channel 11)
5 GHz wireless network name
5 GHz wireless channelSmart (Channel 48)
Wireless SecurityWPA
Wireless modeMode 1
FirewallDefault
MAC address
Software variant-
Boot loader 0.0.3-EE (Mon Dec  4 17:32:53 2017)
Will post the ipconfig when I have an outage next
Thanks. Also the router stats at time of outage.
just had an outage.  Can't access the router during an outage, so can't get stats during.  can give you the logs if that'll help?  Though this time I restarted the router as the outage went on so long.
ipconfig from PC:
   Connection-specific DNS Suffix  . : home
   Description . . . . . . . . . . . : Intel(R) Ethernet Connection (7) I219-V
   Physical Address. . . . . . . . . :
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::d513:52b6:e8d8:97a8%15(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.217(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 29 September 2019 10:24:06
   Lease Expires . . . . . . . . . . : 01 October 2019 22:22:46
   Default Gateway . . . . . . . . . : 192.168.1.254
   DHCP Server . . . . . . . . . . . : 192.168.1.254
   DHCPv6 IAID . . . . . . . . . . . : 347352729
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-EF-77-D2-B4-2E-99-14-C9-71
   DNS Servers . . . . . . . . . . . : 192.168.1.254
   NetBIOS over Tcpip. . . . . . . . : Enabled
and server:
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Link-local IPv6 Address . . . . . : fe80::2992:2b9d:f503:bc72%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.188(Preferred)
   Lease Obtained. . . . . . . . . . : 18 September 2019 19:13:29
   Lease Expires . . . . . . . . . . : 01 October 2019 15:26:52
   DHCPv6 IAID . . . . . . . . . . . : 349453694
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-FD-A4-F6-D4-3D-7E-9E-14-97
This is the 10 minutes or so over the last outage from the event log:
23:05:19, 30 Sep.Receive a DHCP request
23:05:19, 30 Sep.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
23:05:18, 30 Sep.PPP IPV6CP Send Configuration Request
23:05:16, 30 Sep.WAN Sensing Auto sensing Complete, interface selected
23:05:15, 30 Sep.PPP IPV6CP Send Configuration Request
23:05:13, 30 Sep.NTP synchronization start
23:05:13, 30 Sep.WAN DHCPv6 events: INIT
23:05:12, 30 Sep.PPP IPV6CP Send Configuration Request
23:05:09, 30 Sep.WAN Sensing Auto sensing Running
23:05:09, 30 Sep.Success - secondary DNS servers
23:05:09, 30 Sep.Success - primary DNS servers
23:05:09, 30 Sep.WAN connection WAN2_INTERNET_PTM connected
23:05:09, 30 Sep.PPP: IPCP up
23:05:09, 30 Sep.PPP IPCP Receive Configuration ACK
23:05:09, 30 Sep.PPP IPCP Send Configuration Request
23:05:09, 30 Sep.PPP IPCP Receive Configuration NAK
23:05:09, 30 Sep.PPP IPCP Send Configuration ACK
23:05:09, 30 Sep.PPP IPCP Receive Configuration Request
23:05:08, 30 Sep.PPP IPV6CP Send Configuration Request
23:05:08, 30 Sep.PPP IPCP Send Configuration Request
23:05:08, 30 Sep.PPP: CHAP authentication succeeded
23:05:08, 30 Sep.PPP CHAP Receive success : authentication successful
23:05:08, 30 Sep.PPP CHAP Receive Challenge
23:05:08, 30 Sep.PPP: LCP up
23:05:08, 30 Sep.PPP LCP Receive Configuration ACK
23:05:08, 30 Sep.PPP LCP Send Configuration ACK
23:05:08, 30 Sep.PPP LCP Receive Configuration Request
23:05:08, 30 Sep.PPP LCP Send Configuration Request
23:05:08, 30 Sep.PPP: Received PADS
23:05:08, 30 Sep.PPP: Sending PADR
23:05:08, 30 Sep.PPP: Received PADO
23:05:08, 30 Sep.PPP: Sending PADI
23:05:02, 30 Sep.PPP: Starting PPP daemon
23:05:01, 30 Sep.5G WiFi auto selected channel 48 Bandwidth:80M(Reason:boot)
23:05:01, 30 Sep.WAN Auto-sensing detected port DSL WAN
23:05:01, 30 Sep.2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:boot)
23:05:01, 30 Sep.DSL Link Up: Down Rate=69590kbps, Up Rate=20000kbps; SNR Margin Down=6.2dB, Up=12.4dB
23:04:14, 30 Sep.A device connected to Ethernet port 1
23:04:14, 30 Sep.Wire Lan Port 1 up, Speed 1000 Mbps
23:03:58, 30 Sep.Booting firmware v0.00.24.06190-EE (Tue Jun 19 17:25:19 2018)
23:03:58, 30 Sep.System start Button press (PowerButton)
23:03:57, 30 Sep.System up
23:03:57, 30 Sep.Detect and configure Ethernet port1 as LAN
23:03:57, 30 Sep.Hub has activated against the device management system
23:03:57, 30 Sep.WAN Auto-sensing last connection port: DSL WAN
22:55:50, 30 Sep.DHCP device Connected: 192.168.1.189, 2c:f4:32:1a:bd:42, ESP_1ABD42
22:55:50, 30 Sep.DHCP lease issued 192.168.1.189 to 2c:f4:32:1a:bd:42 ESP_1ABD42, lease duration is 86400seconds
22:55:50, 30 Sep.Receive a DHCP request
22:54:58, 30 Sep.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
22:54:58, 30 Sep.Receive a DHCP request
22:49:48, 30 Sep.DHCP device Disconnected: 192.168.1.152, 5c:aa:fd:01:f6:fe, SonosZP
22:49:04, 30 Sep.DHCP device Disconnected: 192.168.1.100, 5c:aa:fd:4f:2e:52, SonosZP
22:48:36, 30 Sep.DHCP device Disconnected: 192.168.1.238, 78:28:ca:90:bc:24, SonosZP
22:48:30, 30 Sep.DHCP device Disconnected: 192.168.1.204, 78:28:ca:80:22:4e, SonosZP
22:48:15, 30 Sep.DHCP device Disconnected: 192.168.1.240, 5c:aa:fd:4f:2e:de, SonosZP
22:48:08, 30 Sep.DHCP device Disconnected: 192.168.1.92, 78:28:ca:80:24:3a, SonosZP
22:47:57, 30 Sep.DHCP device Disconnected: 192.168.1.139, 00:04:30:98:da:91, EE-TV-98DA91
22:47:30, 30 Sep.DHCP device Disconnected: 192.168.1.217, b4:2e:99:14:c9:71, Jasmine
22:47:30, 30 Sep.DHCP device Disconnected: 192.168.1.188, d4:3d:7e:9e:14:97, Holly
22:44:32, 30 Sep.DHCP device Connected: 192.168.1.153, a8:db:03:1b:49:f8, Galaxy-S10
22:43:51, 30 Sep.DHCP device Disconnected: 192.168.1.153, a8:db:03:1b:49:f8, Galaxy-S10
22:43:46, 30 Sep.2.4G Client disassociate from a8:db:03:1b:49:f8 (IP=192.168.1.153) RSSI=0, Rate=0Mbps
22:43:30, 30 Sep.DHCP device Connected: 192.168.1.153, a8:db:03:1b:49:f8, Galaxy-S10
Had another outage - lots happening during the outage it seems.  Lots of this type of thing:
23:39:58, 30 Sep.Multicast stream started by client 192.168.1.217
23:39:58, 30 Sep.Multicast event client join group:224.168.100.1 client:192.168.1.217
23:39:58, 30 Sep.Multicast stream request. client:192.168.1.217 group:224.168.100.1
23:39:58, 30 Sep.Multicast event client leave group:224.168.100.1 client:192.168.1.217
23:39:58, 30 Sep.Multicast stream ended by client 192.168.1.217
23:39:57, 30 Sep.Multicast stream started by client 192.168.1.188
23:39:57, 30 Sep.Multicast event client join group:224.168.100.1 client:192.168.1.188
23:39:57, 30 Sep.Multicast stream request. client:192.168.1.188 group:224.168.100.1
23:39:56, 30 Sep.Multicast stream started by client 192.168.1.188
23:39:56, 30 Sep.Multicast event client join group:224.168.100.1 client:192.168.1.188
23:39:56, 30 Sep.Multicast stream request. client:192.168.1.188 group:224.168.100.1
23:39:56, 30 Sep.Multicast event client leave group:224.168.100.1 client:192.168.1.188
23:39:56, 30 Sep.Multicast stream ended by client 192.168.1.188
couple of these:
23:39:33, 30 Sep.Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->16052,internal ports: 32400, internal client: 192.168.1.217
23:39:09, 30 Sep.Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->23085,internal ports: 32400, internal client: 192.168.1.188
fewer and shorter outages today, but can't see i've been using anything any differently to any other day.
anyone??
Hi @JamesBlonde
Unless @XRaySpeX has any further help to offer, I recommend speaking to our Broadband Tech Gurus
They have access to your account and will be able to look into this for you.
Please let us know how you get on.
Sorry, I see nothing further.
OK well thanks for looking
