by Drifty Established Contributor
internet keeps disconnecting
Hi internet keeps disconnecting getting annoying now
https://www.thinkbroadband.com/speedtest/1498564213579446455
https://availability.samknows.com/broadband/exchange/SDPCNTC
DSL status
Systerm Log
as you can see it says in systerm log
12:40:21, 27 Jun. PPP connection down (FIBRE)
been doing this for a while now
Any Help
47 REPLIES 47
EE Employee
Re: internet keeps disconnecting
Hi @Drifty and welcome to the community.
I'm sure @XRaySpeX will be able to assist once he logs in.
Many thanks,
Lee
I'd like to see the System Uptime from the top of the System Log page, before you do any of the other steps in this post.
Try plugging your router into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets? Are there any wires connected to back of faceplate?
Post the router stats when plugged into test socket. Leave it running a few days & then repost them.
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
I rebooted the router before you post but this is what on top system log
System Uptime is: 06:17:52
Current Time/Date is: 19:21:27 27 Jun
my split faceplate looks nothing like the picture how ever I was able to take the split faceplate off and plug in to the one socket it had.
I'll Leave it running a few days.
Trying the BT Quiet Line Test I can't do that i'm deaf so I dont use the phone.
Thanks.
Does your master socket look like How to access test socket on Openreach master socket ?
I'll always need the Uptime at the same time as any router stats. It's for assessing rates of errors.
here is a picture of my box
my openreach box
and since my reboot on router it has droped 2 mores
but have not drop yet since I done what is showen in the picture.
Ah, that's the most modern master socket with 2 lugs.
Since you did what that is shown in the picture? Plugged into the test socket?
yes since i plugin the test socket it have not disconnect yet we see what happens over the next 5 days
Morning @Drifty
Let us know how you get on 🙂
It done it again
System Uptime is: 31:22:53
Current Time/Date is: 20:26:12 28 Jun
System Log
DSL Status
I'm afraid I can't see anything causing this as you're running from the test socket, but is it actually causing you any problems?
FYI: The System Log doesn't tell us anything that
Loss Of Signal Defect   4   0
doesn't.
4 discons in 31 hours is a bit on the high side but should be bearable.
Hi
Yes keeps droping ever thing on computer and xbox live I cant play games and stream live to viewers with it keep dropping all the time
David
Lost internet all night last night
Hi @Drifty,
Is your internet still down?
Without seeing your router stats + Uptime cannot comment further.
no james it back up this morning when i made the post
It went off line around 12.30am last night
David
Hi Ray
Here dsl status
Here system Log
and here the
System Uptime is: 07:23:45
Current Time/Date is: 15:04:41 29 Jun
David
Thanks for providing these @Drifty.
@XRaySpeX do you have any information that could help @Drifty?
Thanks 🙂
No, it all looks OK. There have been no discons in the last 7 hours.
Are you still running from the test socket?
Thanks @XRaySpeX
Is this still disconnecting for you @Drifty?
Thanks 🙂
