by bradleymilbourn
im a WISP is it possible to get permission to install a antenna on a EE mast
by Star Contributor
Star Contributor
Re: im a WISP is it possible to get permission to install a antenna on a EE mast
Hello and welcome to the community.
Getting access to rig equipment onto existing masts is hugely complex as I am sure you are aware. A mast broadcasting EE may simply have space on it leased by EE. In a case such as this, it will be down to the mast(/land) owner(/operator/agent) to give permission for you to exist on the mast, not EE, unless it affects EE in which case EE will have to be involved aswell.
I am sure one of the EE Community Staff will be in touch with you to see if EE can help though.
EE Employee
Hi and welcome to the community @bradleymilbourn
I will certainly ask our network team in regards to this.
Many thanks,
Lee
EE Employee
Hi @bradleymilbourn
I have sent you a private message to gain some information for our networks team.
Many thanks,
Lee
