by lizfield Established Contributor
how to unblock firewall and ports to be able to access thinpoint
I am trying to access my workplace remote access and I have been asked to check that I have no firewall/ports blocked on my router. How?
Solution
Re: how to unblock firewall and ports to be able to access thinpoint
All incoming ports are blocked by the router. If a Brightbox, you unblock them by Port Forwarding . Unless you are running your own servers you are unlikely to need this for accessing your workplace, if that's what you mean.
Port 25 SMTP outgoing is blocked by EE, other than its own and also NETBIOS..
15 REPLIES 15
Solution
Thank you. I'll pass the info to the tech guys at work. But I don't really know enough myself about how to get remote access via thinpoint. It just won't connect though it did until last week. They said check that no firewall or ports blocked?
Ta
Sent from my iPad
Do you have ADSL BB or Fibre? Are you trying to use a VPN?
Ordinary broadband via bright box router. I looked up thinpoint and it says it is a vpn. Also says it doesn't require any changes to firewall or NAT or ports. Not sure what that all tells me. Thanks
Sent from my iPad
After disabling the router firewall to access work remote access, now I can't get back to the page to enable it.
After disabling my brightbox router firewall to try to access work remote, now I can't get back to the router page.
Risky disabling firewalls. That's what they are there for.
You should be able to get back to change anything, by logging in at http://192.168.1.1 .
Yes I see now, complete disaster - and that link doesn't let me back in. What a mess! Liz Field
Sent from my iPad
All you can do then is factory reset the router.
Sent from my iPad
@lizfield ???
EE Employee
Hi and welcome to the Community @lizfield
Is there anything we can help with?
Many thanks,
Lee
Sorry - I clicked by mistake. New router delivered, firewall problem solved.
Ta
Sent from my iPad
Thank you to EE. New router delivered to solve the firewall problem. Is the green bag/envelope for sending old one back? Or just throw it away?
Liz Field
Yes, if it's a Brightbox. EE own it.
