by ruig6549
how to get my login data to login in my own router
How to get my login name and passsword to login in  my own router
Re: how to get my login data to login in my own router
@ruig6549   Have a read of THIS if you mean EE's BB router
by Brilliant Contributor
If you mean a router bought by yourself and not one provided by EE, then it will be on the back or side of the router.
The router's admin password is written on the label on the router.
by ruig6549
i mean the my login details from ee beacuse the modem router that i bought is tp link n600 model n. tdw9980 and they have an script for ee fibre  i just need the login dtealis my login details do you know where i can have it from ee?
Ah, you mean your BB Username & pwd. Your BB Username you can see in clear by logging into your EE router. Your BB pwd you may have chosen when you joined EE. It may be the same as the 1 you use to log into your EE email and your Member's Centre if you have never changed that.
It depends. More recent BB pwds are a function of the BB Username.  What is your BB Username obscuring any of your names in it?
