by tryinghard Investigator
how do you use your mobile instead of the landline
I have EE mobile and Broadband because I understood that I could use my mobile instead of my landline phone. I find that I need to use the landline more than I want too because the mobile is so unrelieable. My coverage says I should be able to get 4G so mobile usage should be possible. I have been told that I might need to Download something to make it possible. Could someone help me please?
Solution
Re: how do you use your mobile instead of the landline
Have you checked the Network Status Checker there & logged the problem?
Are you able to do WiFi Calling from your mobile?
7 REPLIES 7
Solution
Sorry but I am not sure what you are asking me. Where am I to look for the Network Status Checker, on the computer or mobile phone. I have never tried WiFi calling. Thanks for your help.
Just click on the link in my post.
You asked me to click on your link but there is no link that I can see.
Thanks for your help. I used the phone number you gave me to contact the help line and found that all I needed to do was switch on the WI-FI calling status and now it should work.
@tryinghard  The green wording that says Network Status Checker  is the link.
click the green wording I’ve just posted.
My Status checker was 4g so I should have been able to use the phone as hoped. Now all sorted thanks as EE talked me to switch on WIFI calling. Thanks for your help.
