by kellcall Investigator
how do i find out how long i have had my router for?
i am having serious problems with my broadband at the moment. Intermittently keeps disconnecting. I was wondering if its the router?
6 REPLIES 6
Re: how do i find out how long i have had my router for?
Hi @kellcall
Have you tried restarting your router?
If you think your router is faulty then give EE a call.
Which router is it?
I have restarted the router a fair few times. There was a fault on the line BT went and fixed ut apparently and its still disconnecting throughout the day. So i have called ee again and i am waiting on a phone call tomorrow. Its been a couple of weeks now that this problem has been going on and as a parent to 2 gaming biys in the summer holiday I have had enough of it lol
@kellcall : Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Hi i have a brighbox 2 i have logged on but cant see where i can look for my settings?
Login to your BB2 at http://192.168.1.1 as "admin" with the admin password on the label on the back of the router & follow the path I've given you above.
You would've had your BB2 for some time but that doesn't make it faulty/
