by Jackharris3176 Contributor
google home mini AP isolation issue
Good afternoon,
I have been trying to set up my Google Home mini.  It will be in my man cave at the bottom of the garden, so the wifi signal is provided by a WAVLINK wifi extender I have connected to my EE BB2.
During the set up of the Google Mini, It says it has connected to the Wifi, but that I need to turn off AP isoilation (Sometimes called guest mode).
I have been to the BB admin settings and I can't find this option anywhere.  Am I missing something, or is this not an option to turn off?
Any help would be greatly appreciated.
Re: google home mini AP isolation issue
Hi @Jackharris3176
It's your WAVLINK wifi extender which is the problem. Have you looked in the settings for this network device?
Hi Northerner,
Yes I have looked at the settings for this, and I couldn't see it as an option to turn on/off.
When doing my research, it looked like this was a setting I had to change at the source- i.e the router.  I assume this is not the case?
Morning @Jackharris3176
Thanks for coming here.
If you get in touch with our Broadband Tech Gurus, they will be able to get this looked into and see what they can do to help.
Let us know how you get on.
So I contacted the Gurus, and they say that turning off AP isolation is not an option for EE routers.  I think I have found a solution to the issue by resetting it about 20 times, getting mad and shouting at it, and then it seemed to start working.
Not sure that will help anyone else who has the same issue.
Are you using multiple SSIDs & VLANs on the BB2? That's a form of AP isolation.
