by SianieLOU68
fiber router
My fiber broadband becamr live on the 16th January , ive given it the 10 days stabilisation period,
according to my emails im to get 27mbs guaranteed . Contacted EE last night as im only getting 20mbs .
Did a BT wholesale sheck speed test which was 20.54 mbs .........
can anyone suggest anything that i can do ?
Re: fiber router
@SianieLOU68: Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
