by anaisk Investigator
enable to connect my printer
I switched to EE a few months ago, and I'm not able to connect my printer through wifi.
It's a Brother HL-1212W, without any screen.
When I try to connect, it prints an error message, saying that I must select a 2.4 GHz SSID/ESSID. How can I do it with my Bright box (I don't know its number but it's a small dark grey one).
Cheers.
Anaïs.
Re: enable to connect my printer
Does the printer have a WPS button? See Bright Box router - connect using WiFi protected setup (WPS)
Does the printer show list of WiFi networks it can see? Select the router's SSID & supply its WiFi pwd (to be found on its label) to it. I believe this has to be done on a PC in the printer s/ware installed from the CD with the printer temporarily connected by USB.
of course the printer has a wps button, and of course I've already tried to use it.
there is no list of wifi networks: that's why I wrote "no screen".
could you reply my question, about the SSID/ESSID 2.5 GHz thing??
That's why I wrote you may need to do it on the PC using the supplied s/ware. Obviously I don't know your printer.
Look on the the label on the router for "Wireless network name". That's the SSID. If there are 2 don't use the 1 starting "5GHz-".
ok, I'll change my question then:
how may I know if my router is using a 2.5 GHz frequency?
I don't need advice about connecting the printer, because I don't have any PC, I work on computers and have "only" mac and linux laptops. I just want to understand whether the issue comes from compatibility before trying to find a windows PC.
@anaisk: All wireless routers do have 2.4 GHz (it's not 2.5) WiFi.
They're all personal computers, aren't they? I never mentioned Windows.
Are you here for advice on something you don't know about or what? On any forum when you ask a Q you'll get the answer the responder wants to give whether you already know it or not as he won't know what you know.
