by squig1974 Investigator
ee broadband 300 mbps
i am with Bt on 300mbps and want to change. any of the broadband websites that tell you what deals i can get say i can get EE  fibre max 2 at 300mbps , however when i go onto ee website it says i can only get 76 mbps. i already have 300 with BT so whats going on ? and ideas ? why it says i can get 300 but EE say I CANT ?
thanks
liam
Solution
Re: ee broadband 300 mbps
Ah, yes, that confirms what you have found:
  1. You are currently getting 300 Meg WBC FTTP from BT but EE don't sell that.
  2. EE sell 300 Meg G.Fast as their BB Max products but it is not available at your location.
  3. So the best EE can offer you is 80 Meg VDSL which they sell as their BB.
There are various types of 300 Meg BB. BT does them all but EE only 1.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability DateFTTP Install Process
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsVDSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean)8063.3201957.1AvailableAvailable--
VDSL Range B (Impacted)8061201955AvailableAvailable--
WBC FTTPUpto 1000Upto 220--AvailableKCI2 Assure--
WBC ADSL 2+Up to 1--1 to 3Available--Yes
ADSL MaxUp to 0.75--0.75 to 2.5Available----
WBC Fixed Rate0.5----Available--Yes
Fixed Rate0.5----Available----
BETUp to 2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date04-02-2020
Solution
