by Kimmy59 Investigator
connecting to wireless network
i am trying to connect my amazon kindle to my wireless network but it wont allow me to ! i keep trying the password in but it still wont connect?
6 REPLIES 6
Re: connecting to wireless network
Yes I have done that !
Thanks I will
Hi @Kimmy59
Are you connecting to the correct network and using the correct password?
The wireless pwd of EE routers are usually made up of 3 words separated by hyphens ('-'). Be careful not to use underlines ('_') when scanning the Kindle's Sym key.
Hi @Kimmy59
If the advice above hasn't already helped you get connected, please try restarting both the router and Kindle and start again.
Let us know how you're getting on.
OK, thanks @Kimmy59.
Can you connect any other devices to the router? Please try one that isn't already connected.
