by lloffty5 Investigator
cant get my wifi repeater to work with EE router
my wifi repeater that i have will not work with my fibre broad ee router,i can log in to the admin page for the repeater and enter ssid and my password , it saves the info. but when i go to use the repeater in another part of the house it tries to connect but wont. is there any changes i would need to carry out on my ee router(brightbox 2)
thanx in advance
Solution
Re: cant get my wifi repeater to work with EE router
well success at last .i went through everything on the repeaters admin advanced section and where i was asked to enter my EE wifi password hadnt saved as it had to be entered twice in 2 in different boxes ,once the info was entered it saved the info and hey ho bang connected to router.now i have lovelly extended wifi again ..!! many thanks for all the suggestions and comments
9 REPLIES 9
What is the repeater's IP? Have you reserved it in the Brightbox's DHCP?
Have you disabled DHCP & NAT in the repeater?
What Protocol & the rest of its Settings is the repeater set to?
EE Employee
Hi @lloffty5 and welcome to the community.
Hope the assistance above from @XRaySpeX will assist in getting your issue resolved.
Many thanks,
Lee
HI xray
ive tried for the last couple of days to get this to connect up with some of your suggestions and still nowt haha.logged into the repeaters admin page again and entered the details for my virginmedis wifi (b4 it gets turned off) and no problems,i just enter my vm wifi ssid and vm password and bosh it works a treat.ive done the DHCP entry etc diabled it in the repeater ive turned off firewalls etc security protocols are the same but nowt ..at a loss now
EE Employee
Hi @lloffty5 @XRaySpeX
Not sure If this sounds a silly question, but are WIFI repeaters universal with both Cable style broadband and EE style broadband?
Many thanks,
Lee
dont see why they wouldnt be in my mind, your just extending your wifi signal in the house,so it shouldnt make a difference but i will stand corrected if there is a specific 1 for each. !! i may purchase a newer dual channel version so i can extend 2.4ghz and the 5ghz signals
EE Employee
Hi @lloffty5
I'm sure @XRaySpeX will be able to advise 🙂
Many thanks,
Lee
Solution
EE Employee
There is no need to have same SSID in both main router & repeater. That way you could know which 1 a particular device is connecting to.
