by Rammer46 Investigator
broadband very slow
Hi
can anyone advise please  My broadband connection is almost non existant   below is a copy of the status
Internet
Broadband Type
ADSL
Broadband State
Connected
Internet State
Connected
Time Connected
00:54:48
Downstream Rate
0.57 Mbps
Upstream Rate
0.44 Mbps
[MOD EDIT:REMOVED PASSWORDS AND SECURITY INFORMATION.  PLEASE DON'T POST PRIVATE INFORMATION IN A PUBLIC FORUM]
I think this is not acceptable so any advice please
17 REPLIES 17
Re: broadband very slow
Most of that page from "IP Address" is not required & in fact gives away your passwords etc. I'll try & get it deleted.
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
2. Try a wired speedtest here http://www.thinkbroadband.com/speedtest.html and copy to here just the "Link to this result:" link.
Internet
Broadband Type ADSL
Broadband State Connected
Internet State Connected
Bridge State
Signal
Network
Downstream Throughput (KBps)
Upstream Throughput (KBps)
Time Connected 00:54:48
Downstream Rate 0.57 Mbps
Upstream Rate 0.44 Mbps
Link Rate Mbps
IP Address XXXXXXXX [MOD EDIT]
Broadband Username [XXXXXXXXXXXXXXXXXXXXXXXXXX MOD EDIT]
Wireless
wireless network name (SSID) wireless password Security Channel SSID State Broadcast SSID
EE-BrightBox-29bgyh drive-seal-mad WPA/WPA2 1 Enabled Enabled
No activated wireless ssid
Currently Connected Devices [MOD EDIT: REMOVED CONNECTED DEVICES]
No attached devices
USB Device
Share Name File System Capacity Free Space
No supported device found
Information
Features
Wireless Enabled
Firewall Enabled
UPnP Enabled
LAN & Wireless (Default)
Gateway 192.168.1.1
Subnet Mask 255.255.255.0
DHCP Server Enabled
Internet
Protocol PPPoA
VPI/VCI 0/38
Encapsulation VC MUX
DSL Mode Automatic
Subnet Mask 255.255.255.255
Gateway 213.1.113.80
Primary DNS 87.237.17.166
Secondary DNS 87.237.17.198
George
URGENT: Please delete most of that post below "Link Rate Mbps" by editing it out. You are still giving away your passwords etc. to the public Web.
Sorry, that's still the wrong page. Please follow the path I gave you exactly.
trying to remove the post but I am unable
George
Hi @Rammer46
I have had the information removed for you.
Don't worry it's sorted.
Richard
@Richard_C: Can you do same to OP? Everything below "IP Address" can go.
Thanks @Richard_C.
thank you I will try and send info ref. BB in the morning internet keeps going
only have 0.4 download and 0.34 upload not good enough
George
Hopefully the information that you provide @Rammer46 will help to try and resolve things for you.
Have a great day.
Richard
thank you so much internet is intermittent and fails miserably takes an age to try and load anything wish my contract was nearly up so I could change to a proper realisable system
George
I have an inkling what's wrong with your line but need those full DSL Stats before I can come to a conclusion.
I'm sorry that you feel this way @Rammer46
Let's see what the information you are going to provide brings so that @XRaySpeX can offer his thoughts.
Cheers
Richard
Morning Richard
Thank you for the reply , I have been in contact with EE and they have checked the line , apparently BT had imposed a band width on the line and it was restricted, They are now sorting it and it should be ok in a few days thank you again for the kind assistance
George
Yes, I thought it might be a Banded Profile.
Tremendous news @Rammer46
Thanks for letting us know.
Richard
