Highlighted
by Investigator
broadband upload error
I have an issue uploading some photos to photobox.co.uk and hotmail.com (not tried other sites).  It used to work fine but now have issues.
I've picked a sample photo and connected my laptop to my EE mobile telephone (mobile hotspot) and can successfully upload the photo to both hotmail.com (as an email attachment) and photobox.co.uk.  When I connect my laptop to by EE home broadband and try to upload the same photo it gets an upload error (but no error details) to both photobox.co.uk and hotmail.com.
Any ideas on how I could debug / solve this?
Jon
9 REPLIES 9
Highlighted
Re: broadband upload error
Hi @jonnysmig
Is your laptop connected to WiFi and the internet? Can you browse other websites?
Highlighted
Please post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Highlighted
by Investigator
Yes. I can "surf" fine
Highlighted
Hi there @jonnysmig
Thanks for coming to the community,
Do you have the photo saved to your laptop?
Can you upload a different picture?
Highlighted
by Investigator
Hi Leanne
Yes, the photo is on my laptop. I have tried uploading multiple different photos all with the same end game unfortunately.
I'm at work at the moment but will post my router stats when I get home
Highlighted
Thanks @jonnysmig
Have you spoken to our Broadband Gurus to get this looked into further?
Leanne 🙂
Highlighted
by Investigator
Stats below as requested.  Any help / advice will be very well received
STATUS  Configured CurrentLine StatusLink TypeOperation Mode
--UP
--Fast Path
AutomaticG.992.5 (ADSL2+)
DATA RATE INFORMATIONUpstreamDownstream
787 (Kbps)
11995 (Kbps)
DEFECT/FAILURE INDICATIONOperation Data Upstream DownstreamNoise MarginLine Attenuation
9.8 (dB)4.3 (dB)
17.0 (dB)36.0 (dB)
Indicator Name Near End Indicator Far End IndicatorOutput PowerFast Path FEC CorrectionInterleaved Path FEC CorrectionFast Path CRC ErrorInterleaved Path CRC ErrorLoss Of Signal DefectFast Path HEC Error STRInterleaved Path HEC ErrorError Seconds
12.7 (dBm)0.0 (dBm)
00
00
20
7770136
17803525
STATISTICSReceived DataTransmitted Data
34359738 (Kbits)
32373394 (Kbits)
System Uptime is: 478:03:46
Highlighted
by Investigator
Not yet @Leanne_T
I'll call tomorrow if I get chance when they're open
I just thought I'd try the power of the forum first 🙂
Highlighted
Well, you do have a low upstream sync speed. It's usually around 1200 Kbps. That's the problem with standard ADSL BB. It has a low upstream speed & so it's not suited for heavy uploads. How big is the photo?
You surf fine cuz surfing is mainly downloading.
I bet if you do a speed test on your mobile you'll find it has an upstream speed well in the Megs.
