by AKSHEVA Investigator
Working from home
How to get more bandwidth with ee i they arent taking calls?
9 REPLIES 9
working from home
Does anyone know how to get more bandwidth on broadband at home if EE isn't taking calls?
Re: Working from home
What are you getting at the mo'? What EE package are you on?
normally were getting 72mbits/sec. Lately(for obvious reasons) were getitng about 40, but since were working from home wed like to know if we can get a higher package
Amanda
What obvious reasons? There no reason why you should have gone down from 72 Meg to 40 just like that.
Im thinking its because more people are working from home during this pandemic...
by Pippincp Established Contributor
That is having little effect on UK ISP's most have sufficient bandwidth available.
Are you both using wireless connections?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & numbers in the BB Username & also the SSIDs.
3. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Re: working from home
Hi @AKSHEVA.
Welcome to the community.
If any of your devices are compatible to use a wired connection to your router, I believe this would free up some bandwidth.
Can you confirm this @XRaySpeX?
Jon
@Jon_K : I'm not sure what you mean. Switching a device from a WiFi connection to Ethernet would make that connection more reliable & consistent but would not affect the bandwidth of the BB.
Recent solutions
