by Notmem80
New Member
Wired only access to Smart Hub Admin
Hi
I've just got my Smart Hub running and it seems that Wifi access to the Router admin is possible (with password).
Is there anyway of making the router admin accessible by wired connection only?
Solution
Re: Wired only access to Smart Hub Admin
No, but WiFi access to the router's admin requires 2 passwords, the WiFi's & the admin's ones.
Most routers are much the same.
Solution
by Vanwin Investigator
Couldnt you use an ethernet cable?
@Vanwin : It's not a matter of how OP connects, but how outsiders do.
Ok XRay, I bow to your superior knowledge. I probably didn't understand the problem, silly old lady.
