by Dragonfly Valued Contributor
Valued Contributor
WiFi dropping out frequently, only since getting Smart Hub.
I 've been with EE for a few years, and recently ( 20th Sept ) changed to fibre. I set the new Smart Hub in exactly the same place as the old Bright Box, using the new cable and splitter.
The old BB just worked, I never had any wireless problems, but the Smart Hub is very erratic, it's dropping WiFi all the time.
As nothing has changed other than the router, I can't think of anything else that can be causing this problem. I've tried interpretting the router log, but it just shows lots of DCHP disconnects and re-connects, with no reason I can see.
( The log seems very unreliably anyway, it says my laptop is a 5G device, which I don't think a 7 year old DELL could be.
5G Client disassociate from c0:cb:38:6c:0b:8d (IP=192.168.1.107) RSSI=0, Rate=0Mbps )
I can see dropouts for all our WiFi connected devices in the log, so I don't think it's a device problem.
Is there a known issue with EE Smart Hubs ?.
(I've seen a few posts in here which seem to have been fixed by getting a new router. )
Cheers,
Buzby
Solution
Re: WiFi dropping out frequently, only since getting Smart Hub.
For an EE Smart Hub try separating the wireless channels. On the Advanced / Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-".
Solution
Valued Contributor
OK, done that.
Will report back later.
Cheers !
Valued Contributor
It certainly looks like splitting the 5GHz  and 2.4GHz bands has done the trick, there's not been any dropouts for 24h.
But what exactly does 'splitting' do ?. How can two different bands be treated as one in the first place ?.
The 2.4 & 5 GHz bands are still there but when not "separated" they present the same SSID name to other devices. This sometimes confuses connecting devices. By separating them makes the SH more like the BB2.
Thanks!  Glad I could be of assistance & it is now sorted.
