by e1ement Investigator
Wi-fi speeds insanely low
Hi there,
So I've been getting ridiculously low speeds on my wifi recently, and I can't figure out why. I have had speeds of 0.03mbps (measured by google's network speed test) and at most around 2.5mpbs. There are 5 people who use the wifi regularly, and each of us have many device, but there are probably only 3/4 devices actively using the wifi at one time. But even in the early morning when I am the only one using the wifi, I still get ridiculously low speeds of less than 0.5mbps. The plan we are on is 10mbps with the EE BrightBox router (not sure which one). I have also been getting 1000+ ping on online games, but I am assuming that is irrelevant.
Any help would be much appreciated.
8 REPLIES 8
Re: Wi-fi speeds insanely low
Hi @e1ement.
Welcome to the community.
What speeds were you previously getting?
Has the router position changed recently or has anything new been placed around the router?
Hope to hear back from you soon.
Jon
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
2. Try both a wired & wireless speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
. IRe: Wi-fi speeds insanely low
Hi, I've been getting these speeds for as long as I can remember having the router. It's placed downstairs but all around the house I get speeds such as the ones I talked about earlier.
Re: . IRe: Wi-fi speeds insanely low
Hi @e1ement.
Thanks for this information.
Are you able to post the information that @XRaySpeX has asked for?
I'm sure he'll be able to get to the bottom of your problem.
Jon
The DSL Status is attached, and my system uptime is 304:22:21.
My wireless speed test results are https://www.thinkbroadband.com/speedtest/1546698401862319455
I am not getting these speeds on any application on any device though.
And finally here is the link to my exchange.
https://availability.samknows.com/broadband/exchange/LSCHI
Now can you do a wired speedtest so we have a baseline?
Check your IP Profile. Run the BT Wholesale Performance Test (ignoring all the red instructions) and on the initial results page click Further diagnostics at the bottom. The IP Profile is given in the text box.
