by Smudge95
New Member
Why may I be charged for engineer coming to fix broadband?
I reported a fault with our broadband cutting out today and on the phone I was told they had identified fault and were sending out an engineer. I then recieved confirmation of this appointment however the txt said I may be charged. What is this charge?
Re: Why may I be charged for engineer coming to fix broadband?
Hi there @Smudge95
Thanks for coming here 🙂
Once the engineer has been and looked into this for you and let us know the next steps, if there are to be any charges you will be made aware.
Let us know how the visit goes 🙂
Leanne
They will always warn of this in case it is your own faulty phone wiring that is causing BB issues.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
