by Vickysmithy1581 Investigator
Why is my routers light red
My bright box router is not going green
Solution
Re: Why is my routers light red
Power light on Red all the time means faulty router. Phone EE for a replacement.
8 REPLIES 8
Hi @Vickysmithy1581,
Welcome to the EE Community.
Are you a new broadband customer or have you been with us for a while already?
It's worth running through the steps on our fixing my home broadband connection help page if your connection has been working previously.
Hope this helps. Smiley Happy
Thanks james_b but I've tried that too An the only way I can connect to link 192 is on I phone but can't do it on that an I've tried resetting to 😕
Have you just joined EE Broadband?
Which light? What are the others?
Have you just joined EE or are you already with EE?
What does it say in the Internet section on the initial Status page of the BrightBox after you log in? Obscure your names in the BB Username but post the 1st 2 parts of the IP addy.
Is this for ADSL BB or Fibre? BrightBox 1 or 2?
Does the phone work? Do you get a dial tone? Does it announce your correct no. when you dial 1470 17070?
No been with them for while now
The other lights are not on 😕Just the power and it's red and no other lights An yes it's plugged in An turned on how do I get it to work or how do I order new one as can't even log into my EE
EE Employee
Hi @Vickysmithy1581
Please do give our customer service team a call and they will be able to run through a diagnostic to help.
Many thanks,
Lee
Solution
