by Ned2
New Member
Why is my network so weak but I’m paying premium rate
Re: Why is my network so weak but I’m paying premium rate
Hi @Ned2
You are paying for a service the same as everyone else. No carrier can guarantee a perfect service.
Have you checked EE Network Status Checker?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
