by Julian7 Investigator
Why is EE fibre broadband slower than BT?
I switched from BT to EE in January. I have Fibre Max, and had the equivalent highest level from BT.
I have a Samknows box, which monitors the line speed daily, and this shows that my download speed fell from average 73Mbps to 63Mbps.
I called EE support and the very helpful engineer ran tests, reset things etc, but it made no difference. He said the speed I was getting was within the expected limits and there was nothing else he could do.
My question is, why should this be different? The copper cable is the same. The green box is the same. The fibre to the exchange is the same. Presumably, much of the equipment in the exchange is the same. I have replaced my old Openreach ADSL modem with the EE hub, but that is the only difference at my end.
Does anyone have any ideas why EE is not capable of equalling BT's speed in my case? I shall be going back to BT when my contract expires if it doesn't improve.
Julian
15 REPLIES 15
Re: Why is EE fibre broadband slower than BT?
No reason at all. Even the equipment in the exchange is the same. EE have no BB kit of their own; it's all provided by BT.
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
by Star Contributor
Star Contributor
Thanks in advance for your help. Much appreciated. Here is the info (the format was changed when I tried to post the message):
DSL STATUS This page shows information about your DSL connection. If you are using Ethernet Broadband then this page is not applicable.
STATUS  Configured CurrentLine StatusLink TypeOperation Mode
--UP
--Fast Path
AutomaticG.993.2 (VDSL2)
DATA RATE INFORMATIONUpstreamDownstream
19999 (Kbps)
69077 (Kbps)
DEFECT/FAILURE INDICATIONOperation Data Upstream DownstreamNoise MarginLine Attenuation
14.7 (dB)6.1 (dB)
0.0 (dB)15.6 (dB)
Indicator Name Near End Indicator Far End IndicatorOutput PowerFast Path FEC CorrectionInterleaved Path FEC CorrectionFast Path CRC ErrorInterleaved Path CRC ErrorLoss Of Signal DefectFast Path HEC Error STRInterleaved Path HEC ErrorError Seconds
6.7 (dBm)12.4 (dBm)
2125769281
09295
00
02071
325
STATISTICSReceived DataTransmitted Data
21252819 (Kbits)
26564502 (Kbits)
System Uptime is 110:34:45
Wired speed test results http://tbb.st/1520459499196147455
Exchange is Godalming
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 01483xxxxxx on Exchange GODALMING is served by Cabinet 23
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)8060201953Available----
VDSL Range B (Impacted)73.945.62015.338.2Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 11--6.5 to 15Available----
WBC ADSL 2+ Annex MUp to 11Up to 16.5 to 15Available----
ADSL MaxUp to 6--5 to 8Available----
WBC Fixed Rate2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date20-05-2017
Table invisible! Corrected:
VDSL Range A (Clean) 80 60 20 19 53 Available -- --
VDSL Range B (Impacted) 73.9 45.6 20 15.3 38.2 Available -- --
FTTP on Demand 330 30 -- Available -- --
WBC ADSL 2+ Up to 11 -- 6.5 to 15 Available -- --
WBC ADSL 2+ Annex M Up to 11 Up to 1 6.5 to 15 Available -- --
ADSL Max Up to 6 -- 5 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 20-05-2017
Well, you are well within expected range.
What are router stats from test socket?
I'm not sure what this means, I'm afraid.
Julian
by Star Contributor
Star Contributor
@Julian4 What date did you switch to EE?  Would it have been 15th January?
Yes
by Star Contributor
Star Contributor
@Julian7wrote:
Yes
So I am speculating that the downward slope of the SamsKnows graph shows the fews days of initial DLM optimisation of your line to a stable level, after which you have the plateau of the optimal speed.    So if all things remain the same either EE can't deliver what BT could or the optimisation has not correctly set your speed profile.
@XRaySpeX - what do you think?
The speed according to Samknows appears to have gone down over a few days. Whether this was an actual slow reduction, or just the way Samknows averages the speed, I don't know.
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Post the full router stats & System Uptime when plugged into test socket.
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
The 10-day optimisation is a myth! The DLM runs all the time monitoring your line.
What matters is your sync speeds, not SamKnows speedtests.
@XRaySpeX
Apologies for the delay in getting back.
1. The cable from my router plugs straight into the socket in the wall. There is no microfilter and I do not have one to test, if there is a phone test socket under the plate (I didn't take it off to look). See photo.
2. I unplugged the phone from the socket, rebooted the router and checked the DSL stats again. Copied at the end of this post, although they don't look much different from last time.
3. Did the quiet line test. No crackles etc.
4. Ran the speed test again. Results here http://tbb.st/1520977447890579855
To summarise, it still seems a mystery why my EE connection is 10Mbps slower than BT was.
Julian
DSL STATUS
STATUS
Configured
Current
Line Status
UP
Link Type
Fast Path
Operation Mode
Automatic
G.993.2 (VDSL2)
Upstream
19999 (Kbps)
Downstream
69387 (Kbps)
Operation Data
Upstream
Downstream
Noise Margin
15.1 (dB)
6.2 (dB)
Line Attenuation
0.0 (dB)
15.6 (dB)
Indicator Name
Near End Indicator
Far End Indicator
Output Power
6.8 (dBm)
12.5 (dBm)
16
0
Fast Path CRC Error
0
0
0
0
0
0
Error Seconds
0
0
STATISTICS
Received Data
1600 (Kbits)
Transmitted Data
1204 (Kbits)
OIC, now I'm awake Smiley Wink! Forget all that. There's a 2nd, shuttered, socket in the faceplate, almost invisible to the naked eye, for the phone.
You have a VDSL Interstitial faceplate. This is How to access test socket on Openreach master socket .
Strangely, over three months after my move from BT to EE, my broadband speed has returned to the same speed as it was before. As this graph shows, I suffered an immediate slowdown when I swapped to EE and on about 5th May, the speed increased back to where it was. Happy that the speed has recovered, not so happy that no one from EE was able to identify the problem beforehand and fix it.
Julian
EE Employee
Hi @Julian7
I'm glad you are now back to normal in regards to speeds Smiley Happy
Many thanks,
Lee
