by Rossie67
New Member
Why does my internet keep going down?
My EE broadband keeps going down, just 5mins ago it went down. DY10 area.
Re: Why does my internet keep going down?
@Rossie67 : Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
