by atdmedia Investigator
Why does my broadband slow down when I send an email
Hi Guys, I have standard 20mb down, 1mb up broadband.
When I send an email with atachment (photo etc) via any device through my broadband, the download speed drops significantly, enough to cause any streaming tv service to stop.
Any ideas?
Thanks.
6 REPLIES 6
Re: Why does my broadband slow down when I send an email
When you are sending an email with a large attachment it is going on the relatively slow ADSL ~1 Meg upstream. Also the large attachment is sent broken into chunks & each chunk waits for an ACK to be received on the downstream.
Which router do you have? You may be able to use QoS facilities to prioritise the video over the email. Or just don't send large emails while streaming TV.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
2. Try a wired speedtest, both while sending 1 of these mails & while not, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Hi, I've just setup the QoS so hopefully that will do the trick.  Here's the other info though:-
DSL STATUS This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable.
STATUS  Configured CurrentLine StatusLink TypeOperation Mode
--UP
--Fast Path
AutomaticG.992.5 (ADSL2+)
DATA RATE INFORMATIONUpstreamDownstream
1072 (Kbps)
19175 (Kbps)
DEFECT/FAILURE INDICATIONOperation Data Upstream DownstreamNoise MarginLine Attenuation
5.7 (dB)6.0 (dB)
6.6 (dB)15.0 (dB)
Indicator Name Near End Indicator Far End IndicatorOutput PowerFast Path FEC CorrectionInterleaved Path FEC CorrectionFast Path CRC ErrorInterleaved Path CRC ErrorLoss Of Signal DefectFast Path HEC Error STRInterleaved Path HEC ErrorError Seconds
12.2 (dBm)20.8 (dBm)
00
00
00
22403609
82463317
STATISTICSReceived DataTransmitted Data
4374064 (Kbits)
13679064 (Kbits)
System Uptime is: 50:29:51
https://availability.samknows.com/broadband/exchange/WWBUDE
Hi Guys, I thought the QoS settings had done the trick but unfortunatly not.  Any Ideas?
Only just don't send large emails while streaming TV. With ADSL you have a relatively low upstream bandwidth.
Ok, will do.
Thanks for your help
Thanks! You're welcome :)! Glad I could be of assistance.
