by Cloughaman
Why does my broadband disconnect after 9pm every night?
Re: Why does my broadband disconnect after 9pm every night?
If you would like help with your speed or connection issues, please would you carry out the steps and provide the data as requested in the Need Help with Your Home Broadband Speed or Connection? sticky. This will enable us to diagnose the problem and advise you further.
Hi @Cloughaman
Welcome to the community 🙂
Please get back to us with the information that @XRaySpeX is looking for.
Chris 🙂
by Cloughaman
Service drop out
Hello,
i have just changed to EE broadband after a number of years with BT. The BT service was generally reliable unlike EE which drops out EVERY NIGHT and only comes back on when I reset the router in the morning.
I have had two visits from Openreach and they say the line is working well.
does anyone else suffer from this problem.
THe service fails EVERY NIGHT WITHOUT FAIL.
HELP!!
Re: Service drop out
@Cloughaman: I offered to have a look at your line 2 weeks ago but you never came back. I'll offer 1 more time.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
