by D3009 Investigator
Why does landline internet allow me access to my bank but LTE access does not
Hi all,
Had a weird one today, my daughter could not access her internet banking web site via LTE, as it happens I have a backup connection in the same router over the landline (also provided by EE but Openreach the underlying provider) and this works absolutely fine. will double check the firewall rules on the WAN connections but nothing has changed of late and it has worked in the past from both WAN connections.
URL: https://internetbanking.tsb.co.uk/personal/logon/login/
error:
Access Denied
You don't have permission to access "http://internetbanking.tsb.co.uk/personal/logon/login/" on this server.
Reference #18.448e7b5c.1569589597.6a847aa1
Any ideas?
6 REPLIES 6
Re: Why does landline internet allow me access to my bank but LTE access does no
@D3009   I’ve just tried your link to access TSB and it worked for me via LTE.
Hey Chris, many thanks for the fast response and confirmation of your access via LTE. Guess it can only be my firewall or for some reason been blacklisted on the TSB site. Will do some digging to see if I can pin point the issue.
Just done some further investigation, all the discussions on the error tend to refer to browser settings etc. however in this case that is not so as by switching between WANs one works the other doesn't same browser, same settings. Only difference I could come across was on the routing, LTE had 16 hops and bounced around a different area in the EE network to the landline which had 12 hops.
Anyway have inserted a new rule into the router taking all banking traffic via landline and not over LTE. This works but doesn't resolve the underlying issue.
It might be an EE IPv6 issue. EE has introduced IPv6 on its 4G mobile network, but it doesn't fall-back to IPv4 nicely. Can you change the Profile/APN on your EE devices to APN Protocol = IPv4 only or switch them down to 3G?
Dear XRay,
You most certainly can have a thumbs up, the router I'm using is a Draytek, current settings for IPv6 is 'Offline' as I only configured for IPv4, The settings for Access Mode was 2G/3G/4G, by setting to 3G only works fine, setting it to 4G or leaving it in multi mode fails. So if I understand correctly, if EE are supporting IPv6 on 4G, may be worth my while to configure IPv6 for LTE on the router and set access mode to 4G only. Comments welcome
Suck it & see!
