by Leegriff93
Why can’t I stream movies on my home broadband
Re: Why can’t I stream movies on my home broadband
Hi @Leegriff93
Are you a fibre broadband, ADSL, or mobile broadband.
You need to provide some more information about your problem.
by Brilliant Contributor
Are they movies from legitimate sites like Sky Cinema etc
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
