by paulcumiskey Investigator
Why can't I connect my tp link extender using wps on my brightbox 2?
Solution
Re: Why can't I connect my tp link extender using wps on my brightbox 2?
@paulcumiskey: Have you followed Connect using WiFi protected setup (WPS) ?
9 REPLIES 9
Are you outside WiFi range?
Have you read the extenders instructions?
Solution
Thanks!
How come nothing tells me that wps is not activated by default.
I'll try that tomorrow, although I seem to have trouble logging onto those 192 etc sites.
Cheers, I'll see how it goes
You look in the router to check if it is.
Thanks XraySpeX, great result! , but why do the instructions not mention that wps is off by default on my router?
Thanks again as I was getting ready to treat my hair out with frustration.
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
EE Employee
Hi @paulcimiskey and welcome to the community.
I'm glad you are now sorted.
Many thanks,
Lee
Cheers Xrayspex, got a green light on my wi fi extender now..... But.....
 it doesn't seem to extend the range. It's worse than when I used my plusnet without an extender. Ee was supposed to have the best router but it isnt.
No ISP router is anywhere near the best.
Recent solutions
