Highlighted
Why am I paying for 38/39 download speed but only getting 18 max does this mean
Why am I paying for fibre when I’m only getting standard speeds
Highlighted
Re: Why am I paying for 38/39 download speed but only getting 18 max does this m
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
