What was my IP in the past?
Posted in the open:
@Jenny53 wrote:
Hi hope you can help? I need to find my IP address at a time when someone set up some fraudulent online loans using my details. Is there any way I can find the IP address for two dates (8th May and 12th May 2018). I need to know the IP addresses assigned to my EE broadband/WiFi at the time these applications were made to the loan companies to help prove I didn’t apply for them
Solution
Re: What was my IP in the past?
@Jenny53 : Unless your router hasn't resynced since this event, you can't. It's possible EE has a record of them & will release them to your solicitor.
Look in your router settings to find the current System Uptime & your IP addy. Does it cover the time in question? Unlikely!
Why do you think your IP is involved in this frauduent transaction? Do you suspect it was made from your own LAN?
Solution
by Captgeneralmark Contributor
With respect, @XRaySpeX, I think you have it backwards. The loan company probably have a record of the ip address used to make the fraudulent loan application and @Jenny53 wants to show that it wasn’t her ip address at the time in question.
Yes, thanks, @Captgeneralmark . I noticed well after I posted as @Jenny53 wrote her query entirely as a Subject & that bit got truncated on my 1st copy & paste.
