by ReeceC
What's the micro sim for home broadband
I just started a pay monthly plan for the 4GEE home broadband and when it arrived and I started setting it up I realised it needed a micro sim. Well after looking at every page I could find online about the home broadband I couldn't find anything about it needing a micro sim. It's probably because I've never done business with EE so I'm not sure what to do now
6 REPLIES 6
by Profile closed
Not applicable
Re: What's the micro sim for home broadband
If you have any questions ask @XRaySpeX and they will probably know the answer
by Brilliant Contributor
@ReeceC it should of came with a sim did it not? You need a sim for it to connect to EE and send out the wifi signal
by ReeceC
No it didn't. Only came with the router, power cable, Ethernet cable quick start guide and keep me card
@ReeceC You need to give EE a call and ask where the sim is as they should have sent it with it
It should have been in the same polythene packaging as the KeepMe card.
by Profile closed
Not applicable
Check all packaging but if you've thrown it out call EE
