by Dragonfly Valued Contributor
Valued Contributor
What does this port forwarding indicate ?
I got my new EE Smart Hub running last night, and this morning I checked the logs.
There are a few entries like this, but nothing showing on the 'firewall/port forwarding' tab.
04:45:58 21 Sep. Port forwarding rule added via UPnP/TR064. Protocol: TCP external ports: any->58324 internal ports: 39076 internal client: 192.168.1.166
What is going on ?
Re: What does this port forwarding indicate ?
Hi @Dragonfly
It's updates from your ISP and other devices on your network connecting to the internet, or other devices on your network. (Printer,mobile,etc)
If you disable UPnP then these should will drop off (if you can manage UPnP)
Valued Contributor
Thanks for that. I've just checked what the 'client IP' is.
It's my Seagate NAS, which I'd forgotten about !. ( It's hiding behind the telly ).
I've now turned off UpnP, let's see how it goes.
Cheers !
There's nowt wrong with leaving the NAS ON & its ports auto forwarded by uPnP. It must be intended by Seagate.
