by Urbanspaceman Contributor
Weird connection problems
When I connect to the test socket I am getting approx: 36mbps download speed.When I put the face plate back on it goes down to 12mbps.
There is only one extension in the house and that is where the router was connected originally,when it was connected there I was getting 36mbps.
What can possibly be causing the problem?
Would appreciate any help or suggestions.
Re: Weird connection problems
@Urbanspaceman: Welcome to EE's Home Broadband Forum.
From your description you do seem to have peculiar & possibly faulty wiring. I would assume the original socket used for your router was a master socket. Do both your sockets have internal hidden test sockets? Only master sockets have test sockets & there must be only 1 master socket on a line. Are there any wires connected to back of faceplate of master socket you are currently using?
If you would like help with your BB speed or connection issues, please would you carry out the following steps for starters, which will enable us to diagnose the problem and advise you further. Do both tests from both the test socket & with the faceplate back in place:
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
The orignal socket I had it connected to was an extension socket (Not ideal but had little choice)
The Master socket is an Openreach MC5.the bottom half removes by squeezing the sides.
When I was running the router from the extension socket I was getting 36mbps download speed.When I remove the face plate in the master socket I recieve 36mbps but when the face plate is put back the speed drops to approx 12mbps.
I've even tried it with both phones disconnected but makes no difference.
Well, at least there are not 2 master sockets :). Are there any wires connected to back of faceplate of master socket you are currently using?
Please supply the router stats as requested.
Hi
Yes there are wires connected behind the face plate ( I think they are the extension wires) I have read about interference on the bell wire.Don't know if that would have a bearing.
Connected to the Master socket I have download 36.5mbps and Upload 8.42mbps.But this drastically reduces when face plate is re-fitted.I've also always had a disconnection problem where by the router would restart by itself.
One youtube video states the bell wire is orange and white,I have three wires in the master socket that connect under a clear flap,one of those is orange and white.
The thing I don't understand is if the bellwire was causing a problem how come I was receiving 36mbps when the router was originally connected to it.
