by Robinh112 Investigator
Very Slow Broadband
Hi
I have been experiencing very slow broadband speeds for over a week.
below are my results:
BT Quiet Line Test using main socktet - No noise
Speed test done by disconnecting all wireless and plugged in devices from the router and closing all non essential programme's when running a wired speed test from my PC, I also have tried rebooting the router moving it to a different location but still no change
Solution
Re: Very Slow Broadband
You should be syncing at about 15 Meg instead of the 2268 K that you are. The reason you are not is that the DLM system has put you on a banded profile in response to past errors on your line, at the top of the 4th lowest of these ADSL Banded Profiles, altho' you now have no significant errors. You need to give the DLM time to relent & remove any banding. Leave it alone for at least 7 days & don't reset or resync the router. If it's still banded you should then call EE to get the DLM reset in order to remove any banding. However should significant errors persist the DLM will reapply banding.
6 REPLIES 6
If you would like help with your BB speed or connection issues, please would you carry out the following step for starters, which will enable us to diagnose the problem and advise you further. Do not restart your router to do these tests:
Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
Solution
Thank you the issue is now resolved itself
Glad it's sorted, @Robinh112
Thanks for letting us know.
Have a brilliant weekend. 🙂
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
