Highlighted
by Valued Contributor
Valued Contributor
Urgent query: EE Fibre installation schedule and keeping old number? please
Hi All, Please allow me couple quick urgent questions!
I'm on TalkTalk and the contract ending very soon. If I buy the EE Fibre online, how soon will it be changed over to EE? Within days or weeks?
Also, the EE website says they cannot use my old Talktalk number - is this correct? I believe EE uses the same exchange etc cant see a reason to query that. Id like keep my old number.
Thanks everyone! Have a great day. 🙂
Highlighted
Valued Contributor
Re: Urgent query: EE Fibre installation schedule and keeping old number? please
Thanks.
If my TT contract ends on the 15th Feb. Can I order EE Fibre and request its activated that day, or how does it work?
I will be away on holidays that time too... but if TT contracts not cancelled they will jump my bill to standard price which is big jump up!
Highlighted
Valued Contributor
Hi David. Thanks for your reply!  @David
So its 2 weeks to connect normally and you dont have to be home.
I just double checked my TT account and the end date is actually 20.2.2020. So I should be ok to book EE online by the 6th Feb, correct?
Thus avoid any jump to standard fees and early term charges.
I also believe the router is posted through letterbox so its ok to be away from home....
Thanks again.
Janne
Highlighted
  1. If you order your BB from EE it could take 2 to 3 weeks to migrate it from TT.
  2. There's no reason not to able to take your landline number with you. TT cannot stop it being ported to EE, by Ofcom Regs.
  3. The router is meant go through a letter box but doesn't always, even big ones.
