by R-ainbow24 Contributor
Upgraded to fibre at Christmas can’t keep it can I go standard free?
Upgraded to fibre at Christmas can’t keep it can I go standard free? No fee because I never ever had issues but this fibre spends more time disconnecting itself & yes I’ve checked A B & C & if I wantec
to sit 2-3 times a day checking it I’d quit my actual job 🙈 can’t cope no more my mobile WiFi constantly being used indoors - why is fibre so so bad??? Xx
9 REPLIES 9
Re: Upgraded to fibre at Christmas can’t keep it can I go standard free?
Sorry I sound like I’m taking nonsense just posing quickly before I’m without signal again lol my son got a gaming pc for xmass that’s the only reason for the upgrade but on standard we had the pc,Xbox 1 3 laptops 3 mobiles 2 Netflix on devices etc & never had an issue (box next door to my house) what’s the crack with fibre? X
Good Morning @R-ainbow24
I am sorry to hear that you're not getting the best out of your Fibre Broadband.
Have you spoke with our broadband technical care team about this?
Speak soon,
Katie 🙂
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Thank you for replying these are what speeds were coming back at the time of me trying to get help 0D0DCC8C-1C1F-42E3-92DF-B66CB27078C5.png
 Honestly it’s just naff at least 3 times a day worst in rain/wind but do you actually think it could be fixed? It’s bad luck? Lol
Where do I get router sats
from, my ee online account?
Login to your router & follow my path. Which router do you have?
I got this? I’ll follow your instructions out thank you for your help!
When I’ve called up I’ve been asked to check wires ets etc it’s. Toni g to do with wires coming loose etc the router isn’t even in a room the family use very much but apparently this is were it had
to be & tbh we haven’t had an issue in years when we were on cheap standered 🙈
Sorry, that's nowhere near any of my instructions. Where'd you get http://speedtest.btwholesale.com/ from?
Which router model do you have? If you let me know I can give you more exact steps.
