by Lewcifer Investigator
Unable to open ports - faulty router??
Unable to forward ports.
Have an IP cam, worked perfectly with talktalk, plusnet, sky. Now not working with EE.
Port forwarding set up appears to be ok on router for my port 831. But when checking with external sites the port shows as closed. Or as stealth.
Can access the IP cam on lan with associated port 831 fine.
What else could be wrong?
Solution
Re: Unable to open ports - faulty router??
Done it!!! Fixed it. I think this will help so many people.
I had the cam set up with a static IP.
Port forwarding wasn't working at all.
Instead I let the router pick up address with DHCP server. Then on the router told it to use the cams new IP always.
..then port forwarding (doing exactly the same as I had before) worked!!!!
16 REPLIES 16
Hi @Lewcifer
Welcome to the community. 🙂
This is something our resident broadband expert @XRaySpeX may be able to help you with, when he logs in.
Which router have you? Which IP Cam?
I can view an IP Cam, both home & away, thro' various EE routers.
EE Smart Hub, just got it a couple days ago.
IP cam is foscam HD
Thanks for coming back with the details @Lewcifer
Is this the same IP Cam you use @XRaySpeX?
Leanne 🙂
@Leanne_T : No, I have a D-Link 1. I also think it operates Netwise in a diff way.
@Lewcifer : Did you have to register an a/c at the Foscam site in order to view the camera away from home? If so, do you have to login to it whenever you want to view the camera away from home?
I've got the ddns set up with myfoscam still from the past 10 years. I've checked it out, still working fine. But with this router I can't access it. It's literally the router not actually opening the port.
And no I don't need to log in each time. If I go to the relevant url/IP it should just work.
But it seems the obvious culprit is the router is not opening the port publicly as any port checker website is showing the port as closed/stealth
Hi there @Lewcifer
Thanks for providing the above information.
Have you had the chance to speak with our technical care team regarding this?
Katie 🙂
They said to ask the question here
Show us your Port Forwarding settings.
What does ShieldsUP! report the status of your ports when you use its All Service Ports & also your opened ports with User-Specified Custom Port Probe ?
Shieldsup shows the port as Stealth. Other port checkers show it as closed
Anyone had a chance to look at my port forward settings yet? I need a solution to this asap or I'll have to leave we. Need to be able to access my IP cam remotely.
May I see the Network & Wireless Settings of the IP Cam itself?
Solution
Well done 🙂 ! I thought the answer must lie in the IP Cam's Settings. Like this:Capture.JPG
