by MickyFin
Trouble with new smart hub. Reconfiguring DHCP server on hub causes problems
I have just received a new EE Smart Hub and wanted it to simply replace my existing Sky Hub, using my own long-standing IP addressing configuration.  On the Smart Hub manager I can get to My Network | Change Settings okay, but then I cannot change the default IP and DHCP settings.  It allows me to change the Hub gateway IP address, but then will not allow the DHCP to be enabled.  If I change the Server address range from other than the defaults and then attempt to save the changes it then returns an error message.
The older BrightBox2 allows this sort of configuration to be carried out with ease, but not the new Smart Hub.  It's not so smart after all.
Has anyone else had this problem?
Re: Trouble with new smart hub. Reconfiguring DHCP server on hub causes problem
If I remember correctly you need to change DHCP Range before changing the Gateway IP.
No, it's not smart at all. It's just a marketing word. Forget the SH & use the BB2. It's far richer functionally.
Re: Trouble with new smart hub. Reconfiguring DHCP server on hub causes problems
Hi @MickyFin
Welcome to the community. 🙂
Did @XRaySpeX's advice help?
Please come back and let us know what's happening.
by MickyFin
In the 'IPv4 Configuration' you have to disable DHCP before you can successfully change the Gateway IP to anything that is not in the two default DHCP ranges (172 and 192) that it presents to you.  Example 150.10.10.10.  You then save the changes, with no DHCP.  You cannot then enable DHCP without the error box appearing.
The SH is only useful to me as a dumb Hub to extend the network using another router as the main gateway, thus gaining a couple of extra wired ports.
The point about the BB2 having richer functionality is well taken.
I phoned EE and the best that I got from the networking team was that 'we don't support changes to the SH outside the default setting', which was not very helpful.  The fact is that there is a fault on the device preventing you from doing the very basic stuff that you can do on any other router in the land.  I told them that the old BB2 (from a previous EE contract) will allow me to do what I want, but not the SH. It's crazy!.
So now I have the BB2 as the master and the SH as the dumb slave.  It does not give me the same overall breadth of control as I previously had using a Sky Hub as a master and the BB2 as the slave.  In this combination I was able to enable DHCP on both devices and split the WiFi traffic between the two, and use different WiFi channels as well.
No, you don't! You just change both the Gateway IP & the DHCP range to be on the same subnet before saving w/out touching the DHCP enablement. Doing 1 w/out the other just refuses to save as Invalid settings. As in your example:
  1. Leave DHCP Enabled alone.
  2. Change Gateway IP = 150.10.10.10
  3. Change Custom DHCP range (ignore the 2 default DHCP ranges) = 150.10.10.64 - 253.
  4. Save settings.
  5. DHCP stays Enabled .
  6. Router admin now unresponsive due to IP changes.
  7. Reboot router (there may be some way w/out rebooting but I c.b.a.'ed).
  8. Wait until router flashes that it's connected to BB or not connected as in my freestanding case.
  9. Browse to http://150.10.10.10
  10. Voila!
What does Ethernet section of ipconfig /all report?
