by galorin
Trouble with new smart hub. Reconfiguring DHCP server on hub causes problems
I have recently moved from BT to EE, and I have a problem with the network configuration.
I have a computer on my network (Raspberry Pi running Pi-hole) that is responsible for network-wide advertisement and content filtering.  It's a basic setup that had been running fine for a over a year while I was with BT.  The way it works is, it acts as an authoritative DNS server, with blacklists and redirects at the DNS level.
In my previous setup, all I had to do was tell the BT HomeHub that, when it handed out its DHCP leases, to set the DNS to the Pi-hole.  Everything worked fine.
On the Smart Hub, as soon as I change the DHCP server settings, whether just changing the provided DNS servers to point to the Pi-hole, or even any other dns such as OpenDNS or Google DNS, the device stops working.  It is no longer accessible over WiFi, the ethernet-connected devices are no longer able to get DNS, even after issuing a ipconfig /release and ipconfig /renew cycle (refreshing DHCP info). The Hub itself then reports that it can't connect to the internet.  The built-in troubleshooter gets a new broadband username, but doesn't otherwise fix the problem.
If I turn off the DHCP server and turn on the Pi-hole DHCP server, then the Smart Hub exhibits the same behavior.  All other ethernet-connected devices are able to get DHCP and DNS from the Pi-hole, but the Smart Hub fails to route traffic.
Wifi connected devices in either case begin to treat the WiFi as a captive portal, but with no portal to actually sign in to.
Is my device faulty, or is the DHCP server implementation broken by error or by design?
If it is broken through error, I look forward to a firmware update that solves this issue.  If it is broken by design, please explain the rationale that has led to this decision.
11 REPLIES 11
EE Employee
Re: Trouble with new smart hub. Reconfiguring DHCP server on hub causes problems
Hi @galorin and welcome to the community.
This does sound very unusual.
I wonder if @XRaySpeX can offer any suggestions on this one.
Many thanks,
Lee
Sorry, I don't understand this. What has DHCP got to do with DNS? They are entirely diff mechanisms.
What exactly are you changing in the DHCP? It doesn't have any DNS settings, only basically the range of IPs it hands out.
by galorin
@XRaySpeX
As part of issuing out a DHCP lease, DNS servers can, and often are specified.  I am not at the machine in question right now right now, but here's what the relevant section of ipconfig /all outputs (Active Directory-managed PC where I was the configuring sysadmin)
Description . . . . . . . . . . . : Intel(R) Ethernet Connection I217-LM
Physical Address. . . . . . . . . : F8-B1-56-B3-86-AF
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : REDACTED
IPv4 Address. . . . . . . . . . . : 192.168.101.176(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 19 April 2018 15:07:07
Lease Expires . . . . . . . . . . : 20 April 2018 00:07:04
Default Gateway . . . . . . . . . : REDACTED
192.168.101.1
DHCP Server . . . . . . . . . . . : 192.168.101.249
DHCPv6 IAID . . . . . . . . . . . : 66629974
DHCPv6 Client DUID. . . . . . . . : REDACTED
DNS Servers . . . . . . . . . . . : 192.168.101.249
10.0.0.31
Primary WINS Server . . . . . . . : 192.168.101.249
Under Active Directory, the MicrosoftDHCP server sends out DNS and Gateway information.
Under Linux, DHCPd sends out the same information, without which a client, without static information, will not get an IP address, resolve hostnames, or find a gateway address.  Please see
https://www.tldp.org/HOWTO/DHCP/x369.html
for setting DNS via DHCPD.
While they are different services, they are often used together, especially in a domestic environment.
The primary complaint is, the Smart Hub handles handing out DHCP leases, handing out DNS information, responding to DNS requests and routing traffic.  If anything about the default configuration is changed, my device falls over.  Either I should be unable to change these settings, or it should not fall over if I do.  Allowing a change, and falling over completely is not an acceptable state.
I'm talking about the router not the ipconfig of your Ethernet adapter (which I agree gets much of its info from the router)
Where on the DHCP page of the router is DNS specifed, as you say?
Where does a Microsoft DHCP come into it?
by jim3ex Investigator
I have the exact same problem. There seems to be no option to change DNS servers on the EE Smart Hub (not so smart, guys) and the hub wifi has no DNS when you use the Pi-hole as a DHCP server (which will serve itself as the DNS). So, it seems EEs new hub is not compatible with Pi-hole. So, what 3rd party hub can I use on EE fibre broadband?
DHCP supplies DNS server address. If you replace the DHCP with Pi-hole server, it will provide its own address as DNS server.
@jim3ex: I have told you how to change the DNS on the EE SH in your other thread.
I don't understand. How can you replace the router's DHCP with something else? You can only either disable it or change its IP range. It has nowt to do with supplying the DNS. The DHCP relates only to the IPs within your LAN; the DNS is on the WAN side.
by CarrySheet
The problem is this: You can select a custom DNS server address on the SmartHub (SH) in its advanced settings, but for security reasons the SH will not allow conncetions to addresses in the private IP address ranges, only to public addresses on the WAN side.
The workaround for this is to create some additional rules for dnsmasq on your Pi or it will automatically assign the gateway (Your SH) as the DNS server when handing out DHCP leases.
On your pi, in the directory /etc/dnsmasq.d/
Create a new file
sudo nano 05-custom-settings.conf
Add the line below where x.x.x.x is the IP address for your Primary DNS to be handed out by DHCP, in this case, your Pi IP address. For clarity, thats a comma after the 6.
dhcp-option=6,x.x.x.x
Save and close, reboot. Now for each client device, renew your IP leases on a per device basis to update or wait for them to expire, could be 24 hours.
jim3ex and Galorin you were perfectly clear in what you wrote, its a shame the EE staff lack any kind of technical knowledge regarding their own products. I think its worse they then nominate so called community helpers with little networking knowledge to direct the already confused into a state of frustration.
@CarrySheet wrote:
SH will not allow connections to addresses in the private IP address ranges
Does that mean the LAN IPs of your router, i.e. 192.168.1.x ?
by CarrySheet
The Internet Assigned Numbers Authority (IANA) reserves the following IP address blocks for use as private IP addresses:
  • 10.0.0.0 to 10.255.255.255
  • 172.16.0.0 to 172.31.255.255
  • 192.168.0.0 to 192.168.255.255
Ah, OK, the full gambit of IANA private IP addresses. Thanks.
