by Bungleshark
Technical Question Regarding EE Broadband Modem
I have been with EE for a few months now and I am happy with the service I am getting. My current setup has my EE broadband modem on the ground floor near the phone line, a few network devices plugged in and I'm using the 5ghz Wireless Signal on it (the 2.4ghz channels are all clogged up from neighbouring properties).
One of the devices plugged in is a network powerline adapter. The powerline adapter goes to the office on the first floor which is plugged into a netgear modem. This is currently being used as a network switch but has the ability to be used as modem/router. On the floor above the office is the master bedroom and we get very poor signal from the wireless due to limitations of the 5ghz signal.
What I want to do is swap the EE modem with the netgear modem so that the wireless signal is more evenly distributed around the property. What I need some assistance with is setting up the EE modem as a switch only, if that is possible of course. I don't need any help with the netgear modem as I'm quite proficient with the UI and changing the settings on it etc...
Any help or points in the right direction would be greatly appreciated.
Re: Technical Question Regarding EE Broadband Router
These devices are actually modem/routers but usually called "routers".
Have a read of To make a second Brightbox as a WAP on your LAN to the main Brightbox reading the Primary BB as your Netgear.
The 2.4 GHz band WiFi has a greater reach than the 5 GHz band. If you you are finding the 2.4 GHz channel clogged, you can try changing channel, but it often doesn't matter if it overlaps those of your neighbours.
EE Employee
Re: Technical Question Regarding EE Broadband Modem
Hi @Bungleshark and welcome to the community,
Hope the information provided by @XRaySpeX has helped with your query.
Many thanks,
Lee
