by NIall010 Investigator
Sudden jump in ping every so often
Reply from 146.66.152.2: bytes=32 time=38ms TTL=55
Reply from 146.66.152.2: bytes=32 time=39ms TTL=55
Reply from 146.66.152.2: bytes=32 time=124ms TTL=55
Reply from 146.66.152.2: bytes=32 time=102ms TTL=55
Reply from 146.66.152.2: bytes=32 time=86ms TTL=55
Anyone know of any reason why it is randomly jumping up to 100+ms?
Solution
Re: Sudden jump in ping every so often
The site you are pinging is too busy to respond to your ping at the time. Servers have better things to do than respond to pings, like providing the service they are there for. As long as it is consistent most of the time, that's all you can expect, if at all. Pings are low priority.
(I wrote this last night but for some reason your post disappeared :()
Hi @NIall010,
Welcome to the EE Community.
It could be caused by a number of factors.
Are you connected via WiFi or a cabled connection?
Solution
