Highlighted
Stronger broadband and 4GEE back up with Smart WiFi
Our Smart WiFi uses WiFi boosting discs to bring you a stronger broadband connection. And it comes with our latest Smart Router which works with both Smart WiFI and our Fibre Max plans – which are up to 30 times faster than standard broadband
You’ll also get a portable 4GEE WiFi mini with 2GB of data included every month, so you can stay connected on the go.
More hotspots in your home
Smart WiFi uses WiFi-boosting discs to give you stronger broadband and extend coverage to areas of your home that might have struggled before.
4GEE back up
If there’s ever a fault with your broadband, we’ll boost your 4GEE WiFi mini with 250GB of data until the problem is fixed.
Simple set up with EE Home
The EE Home app makes set up easy. And once you’re up and running, you can use it to manage your connection – no matter where it is in the house.
You can also control different device groups around your home – for example, using it to manage the kids’ WiFi use after bedtime.
Find out more about Smart WiFi on EE >
Recent solutions
