by hawkmoon83
Speed suddenly slowed
Good afternoon
For a few days now the download steed of my Mum’s internet connection has been extremely poor. Resetting the router hasn’t helped. It has dropped from an average max download speed of 2.2Megabytes per sec to around a max 120KB/s now.
Here are the stats:
DSL STATUS
This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable. STATUS
Configured
Current
Line Status
UP
Link Type
Interleaved Path
Operation Mode
Automatic
G.992.5 (ADSL2+)
DATA RATE INFORMATION
Upstream
888 (Kbps)
Downstream
1150 (Kbps)
DEFECT/FAILURE INDICATION
Operation Data
Upstream
Downstream
Noise Margin
15.4 (dB)
30.3 (dB)
Line Attenuation
8.7 (dB)
18.5 (dB)
Indicator Name
Near End Indicator
Far End Indicator
Output Power
11.4 (dBm)
0.0 (dBm)
Fast Path FEC Correction
Interleaved Path FEC Correction
0
0
Fast Path CRC Error
Interleaved Path CRC Error
0
0
Loss Of Signal Defect
34
0
Fast Path HEC Error STR
Interleaved Path HEC Error
0
0
Error Seconds
391
448
STATISTICS
Received Data
8703587
 (Kbits)
Transmitted Data
2170613
 (Kbits)
System Uptime is: 40:49:31
https://www.thinkbroadband.com/speedtest/1549718689589801555
https://availability.samknows.com/broadband/exchange/WNBH
Telephone Number  on Exchange BAYSTON HILL is served by Cabinet 3
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
45
31.5
7.7
5.5
27.4
Available
VDSL Range B (Impacted)
43.9
27
7.6
5
21.5
Available
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 13.5
12 to 15.5
Available
WBC ADSL 2+ Annex M
Up to 13.5
Up to 1.5
12 to 15.5
Available
ADSL Max
Up to 7.5
6.5 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Observed Speeds
G.Fast
VDSL
ADSL
Max Observed Downstream Speed (Mbps)
3.07
Max Upstream Observed Speed (Mbps)
0.89
Observed Date
2019-02-08
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise environment
Status
Bridge Tap
U
VRI
N
NTEFaceplate
N
Last Test Date
30-01-2019
Re: Speed suddenly slowed
Hi @hawkmoon83.
To the best of your knowledge, has there been any environmental changes in her home?
Something placed close to the router maybe?
Jon
Thanks! She is getting far slower than she should be. There have been 34 discons in the last 40 hours. Does she keep rebooting the router? It shouldn't be done too often else the line will seem unstable.
Has she noticed any work being done at the cab or in the neighbourhood recently?
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats & System Uptime when plugged into test socket.
by hawkmoon83
Thank you for your quick responses.  I have got through to EE by phone and the young lady has told me she has discovered something on the line, and they'll be contacting a BT engineer who will be looking at it in next 24-48 hours. Should that not clear the problem, I'll try your suggestions next. Many thanks.
OK, I'll wait on it. Thanks! You're welcome :)! Glad I could be of assistance.
