by Mike211 Investigator
Speed Test
Hi
Using WiFi for my laptop and mobile at home .. I get quite a difference on indicated internet speeds using Speedtest.
My laptop is getting 74.8mps and my smart phone a mere 48.5mps.
I sometimes struggle with WiFi calling.
Are these speeds normal?
Re: Speed Test
Hi @Mike211.
Is your laptop using a wired or wireless connection?
What phone are you using?
Jon
Re: Speed Test
Try here instead: http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Re: Speed Test
Things slightly different this morning.
Confirming both devices on WiFi.
Think Broadband ... Laptop MSI .. 74.7 mbps .... Mobile  Huawei P Smart up from the 40's to 50.5mbps.
Re: Speed Test
Confirming both using WiFI
Huawei P Smart
