by davidp38 Investigator
Smart plugs worked with BT Hub but not now with EE Hub - no help from EE techs!
6 REPLIES 6
Re: Smart plugs worked with BT Hub but not now with EE Hub - no help from EE tec
For an EE Smart Hub try separating the wireless channels. On the Advanced / Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-". Then connect the smart plug to the 2.4 GHz SSID if it can't do 5GHz.
It's a disgrace that EE BB CS hasn't been trained up in this common issue with the EE SH. If it's not a case of  "join this to that" or "switch it off then on" they are bamboozled 😞 .
Hi @davidp38,
Welcome to the EE Community.
I'm sorry to hear Customer Care were unable to resolve this issue for you.
Please let us know how you get on after following @XRaySpeX's advice.
Thanks 🙂
Hi - I have been into my EE Hub settings and note that both bands are set to ON so that is not the cause of the problem I'm having!
Thanks for confirming this @davidp38
I have sent you a private message for further information.
Speak soon,
Katie 🙂
It's not a question of the bands being on but a matter of separating them  You're not looking where I said.
Hi - sorry have been away for the weekend now back at it.  Have just looked in the advanced settings and see that the separate bands switch is ON - please advise further - do I need a new hub since the plugs worked perfectly with BT - 2x plugs are TP-Link 100.  Thank you
