by Neil17f
Smart hub router issue
Just Renewed my broadband contract and received a new smart hub router to replace my old brighbox 2 which worked fine except for the occasional dropping of wifi signal.
My problem is i was getting around 20mbs with the old brightbox router on bt wholesale speedtest and when i connect the smarthub router i get about 8mbs.I can switch back and forth and the results are always the same.I have had a new smart hub router sent out and the results are the same.I have contacted broadband support and they have said their is nothing wrong with the line which i new because of the results with the brightbox but because the speed i get of 8mb is higher then the guaranteed speed ee stipulate then everything is ok by them.What i would like to know is.Has anyone else experienced this issue or does anyone know what may be causing this issue as to why the older router gives faster speeds then the new one when you would of thought it would be the other way round.
Re: Smart hub router issue
If you would like help with your BB speed or connection issues, please would you carry out the following steps for starters, which will enable us to diagnose the problem and advise you further. Do not restart your router to do these tests. Could you do tests 1 & 2 with both the EE SmartHub & the BrightBox 2:
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
by Neil17f
Hi,These are router stats for both routers.
Product name
EE Smart Hub
Serial number
+EEH001+1849017448
Firmware version
v0.00.24.06190-EE (Tue Jun 19 17:25:19 2018)
Board version
1
Data sent / received
288.6 MB / 2.5 GB
DSL uptime
0 days 21 Hours 30 Mins 0 Secs
Data rate
0.97 Mbps/9.82 Mbps
Maximum Data rate
0.9 Mbps/9.9 Mbps
Noise margin (up/down)
6.3/3.7
Line attenuation (up/down)
12.1/33.4
Signal attenuation (up/down)
12.1/27.4
Broadband username
hf18.orangehome.co.uk@FS
2.4 GHz wireless network name
EE-Hub-Cx8j
2.4 GHz wireless channel
Smart (Channel 1)
5 GHz wireless network name
5GHz-EE-Hub-Cx8j
5 GHz wireless channel
Smart (Channel 48)
Wireless Security
WPA
Wireless mode
Mode 1
Firewall
Default
MAC address
44:FE:3B:C1:D4:4B
Software variant
Boot loader
0.0.3-EE (Mon Dec  4 17:32:53 2017)
DSL STATUS This page shows information about your DSL connection. If you are using Ethernet Broadband then this page is not applicable.
STATUS  Configured CurrentLine StatusLink TypeOperation Mode
--UP
--Fast Path
AutomaticG.993.2 (VDSL2)
DATA RATE INFORMATIONUpstreamDownstream
1097 (Kbps)
23796 (Kbps)
DEFECT/FAILURE INDICATIONOperation Data Upstream DownstreamNoise MarginLine Attenuation
6.1 (dB)3.8 (dB)
0.0 (dB)30.2 (dB)
Indicator Name Near End Indicator Far End IndicatorOutput PowerFast Path FEC CorrectionInterleaved Path FEC CorrectionFast Path CRC ErrorInterleaved Path CRC ErrorLoss Of Signal DefectFast Path HEC Error STRInterleaved Path HEC ErrorError Seconds
10.5 (dBm)10.7 (dBm)
144400
00
00
00
00
STATISTICSReceived DataTransmitted Data
821150 (Kbits)
55076 (Kbits)
my exchange is https://availability.samknows.com/broadband/exchange/lcnel
Can't do a wired test yet because my daughter has the only laptop with ethernet connection.
Thanks! 24 Meg sync is about right for your line & that's what the BB2 is doing. There's no reason for the SH to be running at under half that. Normally I'd say the SH must be faulty but you've already tried another.
Why not ditch the SH? It is far functionally much weaker than the BB2. It might be just slightly better at WiFi.
Don't bother with the speedtests. The router stats say it all.
