Highlighted
New Member
Smart hub no connection
I have a smart hub and all the time now for the last 3/4 days it keeps losing connection or connects but no internet...i have the 30 something pounds deal i should had better connection
Highlighted
Re: Smart hub no connection
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & numbers in the BB Username & also the SSIDs.
3. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Recent solutions
