by edwardturner
Smart Hub port forwarding issues.
I have just set up a smart hub.
Trying to use port forwarding to access servers in home remotely.
I can ssh from within the network but when I use forwarded ports connection times out.
External ports say they are open. But are clearly not actually forwarding the ports.
Have tried with and without the firewall, no effect.
I have also tried different ports, restarting the router different protocols although it should make a difference.
The same settings worked seamlessly with a BB2 that was the previous router installed.
Solution
Re: Smart Hub port forwarding issues.
Can you address it as:
  1. From without as Raw public IP:xxxx (remove DDNS from equation)?
  2. From within as Raw public IP:xxxx ?
  3. From within as 192.168.1.x:xxxx?
7 REPLIES 7
Connection from where? Within or outside the LAN or both? Is ssh the service you are opening ports for?
by edwardturner
From within LAN i can ssh into the machines.
When i try and ssh from outside LAN i get time out.
It is initially but i will be adding more forwarding rules once i get this working.
When you are addressing it from within are you using 192.168.1.x:22?
How are addressing it from outside?
by edwardturner
From within LAN as you say: 192.168.1.x:22.
From without ddns set up, which resolves correctly to my ip address, and the forwarded port for a given rule: my.ddns.address:xxxx
Solution
by edwardturner
I was doing it wrong thanks for advice.
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
Recent solutions
