by Mike72
Smart Hub connection to my Mac
I am trying to connect my Smart Hub to a Mac PC. I use the admin password from the back of the router as the Mac asks for a WPA2 passcode. I have done this several times and every time I get an Invalid Password message.
The Smart Hub is already connect to a Windows 10 PC without any problem!
I am using a wireless connection by the way.
Solution
Re: Smart Hub connection to my Mac
You don't want the admin pwd. That's for getting into it & administering it. You want the the WiFi pwd, also given on the pull-out label, You musta used the same for connecting the Win 10 PC.
Solution
by Mike72
Thank you so much. Turned out I made a stupid typing error!
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
